painting wheels..help!
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
so I just bought some s4 Avus 17" with great rubber off of a audizine member in SD to replace my 16" sport stockers. They have a good amount of rash on them with minor slashes and scratches.
I have a black A4 and I was thinking paint them black but leave the center caps stock silver. I need help though should I go
1)flat black and clear coat
2)semi gloss
3)gloss
or I was thinking if I could find gunmetal spray paint that would look good too.
any thoughts would be great..anyone with experience with auto spray paint as far as should I go with the glossier paints with or without clearcoat etc.
thanks alot..will be posting pics of the whole process when I finally decide
2)semi gloss
3)gloss
![Smile](https://www.audiforums.com/forum/images/smilies/smile.gif)
You will HATE how your wheels look when they are dirty if you go with anything besides full gloss. Use a high gloss paint AND clear coat. It will not be ridiculously shiny unless you wet sand between every coat.
ORIGINAL: Soley4pres
nice ..thanks! Any ideas on paint..I went to a few auto places but I couldnt find Dupli Color Black wheel paint
You don't need to use a primer. I wouldn't. I only sanded before the first coat to smooth down some of the rough edges. The rims on my wheels are pretty chewed up in a couple of places, but the paint does a great job of hiding it. So far, the paint is holding up VERY well. I don't have a single chip on any of the wheels. Do a lot of coats of both color and clear.
sounds good..I already bought a can of primer so I will do a light coat of that..I also bought some bondo like putty to fill in some cracks (there was more than I thought after cleaning them) so no sanding after the paint and before the clear coat?
You could sand very lightly with maybe 1500 grit between the final color and the first clear coat, but I didn't.
