p1136?
Old 05-17-2009 | 07:12 PM
Audacity's Avatar
Default p1136?
went and got the car scanned at advanced auto since she doesn't boost anymore. the code that came up was p1136. looked in my service manual says long term fuel trim add. fuel, bank 1 system to lean? anyone know what this is or how to fix it?
Old 05-17-2009 | 08:21 PM
Interceptor's Avatar
Old 05-18-2009 | 12:13 PM
Audacity's Avatar
so are you trying to tell me theres a hole in a hose somewhere?
Old 05-18-2009 | 12:24 PM
Yes I would check for a leak and also check the O2 sensor.
Old 05-18-2009 | 12:35 PM
Audacity's Avatar
any good starting places? umm would this be cause by a leak on the first pipe right off of the turbo before it goes into that metal cross pipe that runs along the front of the car?
Old 05-18-2009 | 12:46 PM
redline380's Avatar
Legal Moderator
what your code means is that your engine is either getting too much unmetered air or it is unable to supply the needed amount of fuel. odds are that it is letting in too much air. most common culprits are maf sensor or vacuum leak or check any air lines from after the airbox.
Old 05-18-2009 | 01:19 PM
Audacity's Avatar
alright then. ill get on it. thanks guys. anyone have like a diagram off all the hoses and pipes and stuff. it would probably be on the one that i would never see.
jamestown478
06-27-2011 01:11 AM
thebeav
01-11-2011 11:09 PM
sivak.puvvula
07-15-2010 12:11 PM
sound227
07-17-2007 08:45 PM
jaydubyagee
12-04-2006 12:23 AM
