P0455 / Large leak. Help?!
Old 06-28-2008 | 06:51 PM
RedShoeRider's Avatar
Default P0455 / Large leak. Help?!
Good Evening, all:
The car: '99.5 A4 2.8 quattro.
The code:
Address 01 -
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D04
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
Readiness: 0000 0000
The problem: Where do I begin troubleshooting this? Is there a "most common culprit" on this chassis/engine?
Thanks!
-Red
Old 07-01-2008 | 11:26 PM
Default RE: P0455 / Large leak. Help?!
Anyone?
Beuller........Beuller........Beuller.......
Old 07-01-2008 | 11:42 PM
Tweaked's Avatar
Honestly, the gas cap is the most common for a large leak.
Perform a visual inspection of your EVAP system, look for torn hoses or even a crack in your gas tank.
Run the LDP and listen for leaks. Your EVAP purge valve might even be stuck open. Just start and diagnose systematically.
plinko89
11-26-2018 07:03 PM
Gfunk176
B7 Models
03-25-2011 10:41 PM
plinko89
01-11-2011 11:47 AM
jerkyboy
07-27-2010 01:15 PM
Bass402
06-12-2007 01:23 AM
Quick Reply: P0455 / Large leak. Help?!
