Overheating Problems
I have been having issues with my '97 2.8 AFC overheating. I tried replacing the thermostat and flushing the system a few times, and have also replaced one of the sensors (the one on the back side of the radiator, driverside of the car).
If I drive with the heat on it will drop back down to regular operating temperature after a little while.
I have also noticed that the electric fan on the passenger side of the radiator doesn't seem to turn on. I thought it might be broken, but I hooked it up to a seperate power source to check it and it still works fine.
Any suggestions? The only other thing I can really think to change would be the water pump, but I don't know if it seems like that is what is causing this problem.
The passenger side fan is the AC fan so that shouldn't matter I don't think. As for the flush, I had one done on a prior car along with a pressure test for $25. It's inexpensive enough that I'm tempted to take the radiator out of my A4 and have it done the next time I put the car in service position.
