overboosting with n75 and mbc
RE: overboosting with n75 and mbc
I might need to be corrected on this but I am assuming that gated controller has a ball and spring but will bleed out as well. And ball and spring type controllers will not bleed out. Monk you just hook the controller between TN and Wastegate w/o a teeright? Thanks for the link for turbosmart
ORIGINAL: awwdii
Monk you just hook the controller between TN and Wastegate w/o a tee right? Thanks for the link for turbosmart
ORIGINAL: awwdii
Cincytt,
Turbo Kraut said you have had experience with that one on your brothers car. Is the one I gota bleed style mbc? I know it says its gated on the web that I got it from but when I took the tee apart it had a ball and spring. I heard it exhaust from the mbc when I opened it, the controller seemed ok but I really have my doubts about that tee. Do you recommend a certain MBC?
Cincytt,
i thought about that one, but was is the third hole for? if it is for nothing and you plug it...... with what? there is nothing in that kit that you would be able to plug it with
like i said, i have one similar to the one in the pic up in like the first post...... and i will run it till it is junk, then come back and replace it with something better
#20
Yeah it almost looks like an air compressor pressure adjuster but I am sure the internals are different. I am picking up the audi tt DV tomorrow then I will pick up that turbonetics to lower my psi. Hopefully it works Thanks for all the help guys will keep you posted on progress. I still
