over heating problem ??
ok so i got a 99 audi a4 2.8 v6 ive noticed in this couple months that the temperature gauge goes a lil bit over the half point. is that bad? is it over heating? what could cause the car to overheat just a lil bit
There are lots of variables here and not much information. First you need to figure out if the readings to the temp gauge are actually accurate. Does the temp gauge go back down if you crank the heat? Is the heat even hot? Does the coolant temp go up at idle? What does your coolant look like? Have you ever replaced any parts in the cooling system like the t-stat, coolant temp sensor, heater core, etc?
if i turn on the ac the needle drops to the dead middle but i havent tried it with the heater. i think its the extra fan that turns on that cools it. and sometimes it stays in the c so idk what it might cause it to not read the temperature
It's not bad, just a tight sqeeze. Two pointers:
1. Loosen the cap on the coolant so there is no pressure when you pull the old one.
2. Tie a thread around the little plastic clip that holds it in. You'll thank me the first time you drop it, and the next time, and the next.....
