One of my pistons doesnt seem to be firing
Ok, yea I found it. But now heres another problem. The thing looks almost brand new. Should I buy the cleaner anyway and use it? Or should I start looking for another sensor?
And is there any way I can test the thing to see if its working right?
It is cheap and can't hurt to do it, so I'd say go for it. You could also get some dialectric grease form an auto part store, it is cheaper than the contact cleaner from the Rat Shack and does the job quite well. It is use extensively by installers of electronics on cars and motorcycles. JM2CW.
Yea it makes a nasty chugging noise. But it still turns on. I plugged a DTC reader into it, and from the software that came with it, this is the info I got.
P0102 MAF or VAF A curcuit low input
P0134 O2 sensor CKT no activity (Bank 1 Sensor 1)
P1196 Manufacturer Control Fuel Air Metering
p1198 Manufacturer Control Fuel Air Metering
P1425 Manufacturer Control Auxiliary emission controls
P1472 Manufacturer Control Auxiliary emission controls
So, anyone have any clue as to exactly what my problem is?
Ok, well since the MAF looks clean, and the cleaner is on its way. I was also told to check the ignition coils, spark plugs, and O2 sensor. You guys know of any FAQ on what I should be looking for? If theres any way to tell visually if the parts are bad?
what FAQ do you need?
you can not look at the MAF element and tell if it is bad. sometimes you can visibly see a buildup of something on it but it can still be bad and look brand new. you can get a general idea the MAF is bad by looking at CEL codes and plugging/unplugging it and seeing what happens. you can find out for sure if its bad by running a log of MAF readings in VAGCOM and looking at the numbers.
ignoring what the car is telling you (codes) and just replacing coil packs because you feel like it will cost you a lot of unnecessary money. its not a bad thing to replace the spark plugs as they are cheap but might not be necessary right now either. i would wait until you fix your problems in case you just foul your new spark plugs right after installing them.
to find your O2 sensors- locate your turbo (passengers side, on the left of the engine if you are standing in front of the car), it may be underneath the stock airbox.
directly behind the turbo there is a sensor coming out of the pipe at a 90* angle with a few wires coming from it going to a plug underneath the coolant reservoir. this is the primary O2 sensor (bank 1 sensor 1)
behind that sensor is your cat. converter, then behind that is the secondary O2 sensor (bank 1 sensor 2)
#18
Err yea, I didnt mean swap out the ignition coils as well, just the spark plugs. Though I was told that the ignition coils do tend to go bad on this model.
So is there any way to tell visually if there is an issue with the ignition coil? Or would I only know by replacing it?
