once again LOL
once again LOL
lol today i got a check engine light on AGAIN haha
for the past two times it was on for a day and it went off o.O
i wonder if it is going to go off or not cuz this is just messing with me ^^
Do you know what error code made the light come on?
I had the EPC come on one night when I was low on fuel. After filling up, the EPC light went off.
My only 2 engine codes are P0322 35-10 (engine speed sensor), and P0420 35-00
Does anyone know what the 35-10 or the 35-00 represent?
Thanks
Thanks
check out this link -
http://wiki.ross-tech.com/wiki/index...5/P0411/001041
Just type your error codes into the search bar, and you'll get good details back.
So, for p1146 . . .
17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
Possible Symptoms
Malfunction Indicator Ligh (MIL) active
Possible Causes
EVAP Purge Valve (N80) faulty
Wiring/Connectors from/to EVAP Purge Valve (N80) faulty
Fuel Pump Relay (J17) faulty
Possible Solutions
Check EVAP Purge Valve (N80)
Check Wiring/Connectors from/to EVAP Purge Valve (N80)
Check Fuel Pump Relay (J17)
So, for p1146 . . .
Possible Symptoms
Possible Causes
Possible Solutions
