Oil weight
Castrol, Castrol Syntec 5W-40
Chevron, Chevron Supreme Synthetic 5W-40
Elf, Elf Excellium LDX 5W-40
Kendall, Kendall GT-1 Full Synthetic Motor Oil 5W-40
Mobil, Mobil 1 0W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula 5W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula Ultra 5W-30
Pennzoil-Quaker State, Quaker State Full Synthetic European Formula 5W-40
Pennzoil Quaker State, Quaker State Full Synthetic European Formula Ultra 5W-30
Seventysix Lubricants, 76 Pure Synthetic Motor Oil 5W-40
Texaco, Havoline Synthetic 5W-40
Total, Total Quartz 9000 5W-40
Valvoline, Valvoline Synpower 5W-30
Valvoline, Valvoline synpower 5W-30
courtesy of CRAZYHAWK
i personally run Kendall GT-1 Full Synthetic 5W-40
I use nothing but Mobil 1 0w-40 (European Formula). It is fully synthetic, meets ACEA A3 standards, is suppose to protect against sludge and is designed for cold weather protection. I also would recommend using the oversized oil filters.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils. These oils meet SAE specifications for the low temperature requirements of a light oil and the high temperature requirements of a heavy oil.
The colder it is the lower the number you need so the oil stays fluid when cold. vice versa for living down south.
And Synthetics handle cold weather better. But, we are talking arctic cold (or Maine) for that to be important to most of us.
Always the contentious subject... ask 100 mechanic's get 100 answers. I generalize:
Rule of thumb: Turbocharged or abused (flogged hard and put away wet) then by all means, go quality synthetic, such as Castrol Syntec or Mobil 1
Normally aspirated engine (not turbo/supercharged) and not driven by a boy-racer, mineral oil is more than fine.
Per other posters, viscosity (weight) is a factor of how old the engine is, what you want out of your engine (efficiency vs extra protection) and where you live, in terms of expected temperature... if you do seasonal oil changes, you may want to change viscosities. Arizona in the summer on a high mileage engine, 20w50 is great. Maine in the winter, 0w30. Think of a thicker oil (20w 50) as being thicker, and harder to pump. This means that it's good on a word engine, but you sacrifice some efficiency and it's much harder (slower) to pump on a cold am.
The synthetics hold up much better in either extreme and knowing cold starts is hard on bearings, I would go synthetic in the winter in Maine, especially on a turbo motor.
FYI, We (a professional racing team) actually ran Kendall 1 mineral in a 993 (that's a Porsche, ya'll) RSR at the 24 hours of Le Mans and it held up better than 12 hours at Sebring Mobil 1. Seriously.
My last caveat here is don't switch from mineral to synthetic if you have a long history of mineral oil in a higher mileage engine, unless you don't care if your engine leaks. The mineral oils leave deposits on seals that some synthetic detergents may remove, exposing your older seals to potential failure.
