Oil temp gauge maxed out!!
Old 04-13-2014, 12:53 PM
86f250xlt's Avatar
Default Oil temp gauge maxed out!!
I have a 96 a4 Quattro and now suddenly my oil temp gauge is maxed out idk if maybe I bumped the wire while doing my timing belt and water pump or what!? I didn't have this problem before and I just noticed it! I have already looked up its location and I am dreading of it is bad but is there usually anything else that could be causing this?... Oil cooler plugged (if it has one, I can't seem to find anything on one!) car seems to be running great still and doesn't smell un-usually warm... So I don't know what's going on... I am going to let the car cool and see if it changes or not but I don't know I just spent a little bit of money getting this car moving again and I don't want it quitting on me already
Old 04-13-2014, 01:10 PM
bshusted's Avatar
What did the coolant temp gauge read? My bet would be that the sensor is bad/unplugged.
Old 04-13-2014, 01:30 PM
86f250xlt's Avatar
Coolant temp is normal and even after letting the car cool its still maxed!... But I do also have a cluster with bad tach and speedo
Old 04-13-2014, 01:31 PM
Pbcrazy's Avatar
Your driving without a tach and speedo? Pure genius.
Anyways, more than likely it's just your cluster if it stayed at max after the car is turned off
Old 04-13-2014, 02:10 PM
86f250xlt's Avatar
I use GPS on my phone for speedo lol... And no gauge drops when key is off so I'm thinking its either sensor or I have a short
Old 04-13-2014, 02:34 PM
Pbcrazy's Avatar
Probably just the sensor/sender then
Old 04-13-2014, 06:02 PM
86f250xlt's Avatar
Thanks guys! I will check into it soon
Old 04-13-2014, 09:24 PM
adam044's Avatar
May want to look into getting that cluster working correct... just saying.
Old 04-13-2014, 09:37 PM
Pbcrazy's Avatar
Ya. Especially if you are a manual that is tuned, running without a tach is just plain stupid.
Old 04-13-2014, 11:14 PM
86f250xlt's Avatar
I am running a manual but its fully stock at the moment!... I'm going to be updating the cluster and dash
Quick Reply: Oil temp gauge maxed out!!
