Oil on the spark plugs help?
Need some help, a while back, my cel came on, and of course i go and get one of those free diagnostics at autozone. i get code number P0432, and assume that it is something that can wait for a little while. Well, today, i just swapped out my spark plugs and changed the air filter, but when i changed the spark plugs, i had four that had oil on the threading of the plugs, and two that were completely normal. any ideas of what this could indicate?
yes, i know what the code means, but ime wondering if that has anything to do with why the spark plugs are oily.
It's a valve cover gasket. Ours have 2 pieces, mine also leaked around the spark plugs. There is a DIY on passat forum
http://www.taligentx.com/passat/main...vecovergasket/
well just change the plugs use ngk's by what i understand people on the fourms say the ngk's work better than the bosche and im running the bosche with no issue's when you change the plugs just check back in a few 1000 miles and see what you get but i wouldnt worry about that at all
