Which oil pan is this, and do I need to drop the subframe?
My father crunched the oil pan on his
2001 A4 Avant Quattro 1.8T (or at least that's what the VIN says)
However, the oil pan doesn't look like the ones that I've seen online -- it looks like it should drop straight off (e.g. like this one: Oil Pan Audi A4 Quattro Avant VW Passat 1.8 2001 2002), but the internet is full of horror stories of having to drop the subframe, losing bolts in bell housings, etc.
Question 1:
Is this a 2001 A4 1.8T oil pan?
Question 2:
Do I need to drop the subframe to get it off? Looks straightforward, but looks can be deceiving.
Question 3:
Do I need a gasket for this, or should I just use RTV?
Question 4:
Anyone know how many book hours this is? Can I do it outside on jackstands reasonably quickly?
Question 1:
Question 2:
Question 3:
Question 4:
Yes, those pics are the transmission pan. Easy to replace, but refilling the trans can be a bit involved because it gets filled from the bottom. If you go to Blauparts.com, there is a write up of how to re-fill the trans. They also have filter and ATF kits.
If it were the engine oil pan that needed to be removed, yes, it's a significant PITA.
Good luck
Good luck
Thats a tranny pan but for all your oil pan needs check this, it seems to make the job a less pain in the ***
http://www.motorgeek.com/viewtopic.p...it=1.8+oil+pan
a4/passat oil pan trick/cheat :: motorgeek.com
The real gem here is the modified engine mounts. I already have one that is damaged and can be cut up, I think I'll find another in case I ever need to do this again.
Good find!!
Thanks
vtraudt
11-28-2012 08:45 PM
foxracing4500
02-26-2011 08:52 AM
