oil leak front right axle screw
Old 08-30-2010 | 09:30 PM
dahaker's Avatar
Default oil leak front right axle screw
Hey guys i have a fwd tip 1.8t 2001. About 2 month ago my mechanic replaced the trans oil pan and right axle due to oil leakage through the trans pan seal(the last owner took a serious bump and hit the pan hard) after those repairs there were no leakage for about 2 weeks. From that moment on I could see oil on my garage. i thought it was old oil washing out but its a bit light clear brown. idk what color is the atf trans fluid so to check what was going on i cleaned it and the other day it was not leaking so i drove off but when i came home and parked the car 5 min later I could see it leaking im thinking this is when i shift or drive off. I checked under the car and and i traced the oil to one of the 12 point screws that hold the axle to the transmission. Can this be a broken seal? do autos have this kind of seal? is my tranny shot?
I appreciate everyone's help im going through a tough time with the hurricane passing through hehehe.
Old 08-30-2010 | 09:44 PM
onepoint8tee's Avatar
Audi atf is honey colored, a little lighter than fresh oil. There is a gasket between the axle and trans that basically holds in axle grease, but not fluid. It's possible that the prop on the trans is leaking - before the axle - on the trans case. If thats true then the side of the case that secures the prop needs removed, and there is a seal to replace.
Maybe you can see what I mean by looking at this:
Old 08-30-2010 | 10:10 PM
dahaker's Avatar
do you think its expensive to fix that seal? wear can i buy it?
Old 08-30-2010 | 10:20 PM
Should be doable without having to drop the trans. But still wouldn't be real cheap. I'd imagine it calls for at least a few hours of labor, but idk. If you DIY then it'd be the cost of the seal, a new axle gasket, and fluid. As for where you can buy it, the seal itself should be real cheap even from the dealer. This is not a common replacement item so I'm not real sure about any of it. Def make sure thats the problem before you do anything, of course.
Old 08-30-2010 | 10:37 PM
dahaker's Avatar
ok thanks for the info bro im gonna take it to the mechanic to see what he says and the fix cost.
thanks
Old 08-31-2010 | 05:07 PM
dahaker's Avatar
btw I found this trans diagram and pointed out these seals. Are these the one you are talking about?
Old 08-31-2010 | 05:44 PM
Yeah more like the shaft seal than the O-ring. If it was the O ring I don't think fluid would seep onto the axle bolts but idk for sure.
Amybc96
B7 Models
06-29-2015 08:37 PM
01quattro
03-27-2012 05:21 PM
hottubbrad
12-06-2011 05:46 PM
hiwords
09-29-2007 11:16 PM
707782y
03-23-2006 02:04 AM
