Oil bubbling when doing Boost leak check...?
Old 11-01-2009 | 05:04 PM
2fast4u66's Avatar
Default Oil bubbling when doing Boost leak check...?
So while back I tried to do a quick boost leak check and was in a rush and forgot to put the hose back on the check valve. Of course all the air came out as it was going in.
Today I had sometime and went to the store to get some pvc and pressurized the system. I pressurized it at the intake tube that connects to the maf and took off the pankcake valve and plugged it. Put 10 psi in the system but soon as any air was put into it, there are bubbling sounds from what sounds like near the oil pan. I took the oil cap off, and couldn't feel/hear anything and same for the coolant reservoir. Any suggestions? Searched but no luck and looked at some vacuum diagrams with still no luck of being able to tell what would cause this. Thanks for help!
Old 11-01-2009 | 10:33 PM
bbboy's Avatar
Member
Happend to me also, I heard other people experienced it. Don't know...interested to find out too.
Old 11-01-2009 | 11:25 PM
2fast4u66's Avatar
Only thing i can think of is the oil return line is getting air in it.
Old 11-03-2009 | 10:45 PM
pimphell's Avatar
could be seaping past the rings or the valve seals
Old 11-03-2009 | 10:47 PM
Andrew149's Avatar
could be a clog and oil is recirculating
Mike02A4
04-26-2010 02:59 PM
flynnr
03-02-2010 07:24 AM
huviduc
08-17-2007 02:51 PM
onepoint8tee
06-27-2007 04:38 PM
Quick Reply: Oil bubbling when doing Boost leak check...?
