oh boy
Old 04-19-2011 | 08:08 AM
b5blazing's Avatar
Originally Posted by chowmouse
To realign throttle turn the key to the ON position and leave it there for 3 minutes. You should be able to hear faint mechanical noises coming from the MAF. That's a start, but I reckon you might have a deeper problem, caused by the modification and a misunderstanding with the ECU and the mod
i dont think so but possible. and i did try the key thing as well as the terminal thing key on foot to floor happy horse ****. and ecu was flashed by a tuning company that does it a million times a year. not to sound defensive but no mis understanding
Old 04-19-2011 | 08:16 AM
b5blazing's Avatar
^^^ Ignore the spam
Yes you can disconnect your battery for a few minutes then reconnect turn the key to the on position with out starting and that can do a close alignment.
tried this too. this was whole mess was cuase cuase my battery had a dead cell and during cranking (first start up after install) battery dipped and cannot return above 10.6 volts. if and when a 2.8l 30v drops below 10.6 volts it draws the throttle poss. sensor out of align ment. when this happens all the ( touch terminals key on, foot to floor key on and key off, disconect) doesnt work. if it happens too many times you might have to replace throttle body.
and spam doesnt faze me. im here to learn
its scary when the mods let your thread run.
this is one of those times i would love to have devil chew up my thread.
and my VAG is in brooklyn ny. just checked tracking number
Old 04-19-2011 | 08:18 AM
b5blazing's Avatar
[QUOTE=bradtyler02;1305567]don't forget to find your radio code first, if you still have the stock head unit[/QUOTE
yeah thAT was first thing to go. i like touch screen
Old 04-19-2011 | 10:45 AM
rcheing's Avatar
Hey man, I don't have anything useful to contribute towards your issue but I wanted to ask, can you make your future thread titles more meaningful? This helps out future forum members when searching for a particular problem. Thanks! :-)
Old 04-20-2011 | 01:02 AM
b5blazing's Avatar
yeah no problem chief. you got it
Old 04-21-2011 | 08:19 AM
b5blazing's Avatar
bump
run
Old 04-21-2011 | 11:21 AM
chocalotstarfish's Avatar
Super Moderator
pull codes thats going to be the next step until then we are just guessing
  #18
Old 04-21-2011 | 03:47 PM
johnson90512's Avatar
yeah see, i am having this same problem, can you describe the "touch terminals key on, foot to floor key on and key off, disconect" blazin pm me about vds software...i may be able to help in that aspect.
  #19
Old 04-21-2011 | 06:14 PM
jinxonator's Avatar
Do you have "secondary air flow too low" after the install as i had those codes pop up after i installed the g2 with the ecu flash. the car can be started without the ecu, but shouldnt be driven to prevent any damage to the car
  #20
Old 04-23-2011 | 07:55 AM
b5blazing's Avatar
okay this is not an adaptation this is for limp mode purpose. as far as i know
touch terminals together is easy. remove both terminals possitive and negitive and hold them together for a few. i always used zip ties..
key on key off. remove negitive cable from battery. reconnect turn key to on poss. wait 2-3 minutes (you will hear tb buzzing with your hood up) try to start. if start is not achieved. key off, key on push gas pedal to floor hold for 30 sec release gas pedal start car.
i cannot say they work. t
