OBD II prob, serious(?)
i think my car is goin to sh*ts. the problems i need to fix are growing into a mountain.
the biggest problem atm i think is that whenever i check for codes via obd II scan, it hangs. the engine link, ABS link, SRS link, AT link, they all just attempt to scan, but never produce codes, or say "no codes found." i don't know why it's not working anymore.. i'm quite certain it's the car and NOT the scanner..
this seems serious and may help resolve other problems i am having if i can get some codes... can ANYONE help?
my car will owe you its life. we're hitting 100k any day now, but we would like to make it much longer!
RE: OBD II prob, serious(?)
ORIGINAL: hiwords
why do you think you have codes?
ORIGINAL: Tweaked
What problems are you having? Have you tried using the scanner on another Audi?
Your cowl isn't by chance clogged with leaves, leaving your vital electronics in a pool of water, is it...?
where might the cowl be located? is that a portion of the radiator? i will check this tomorrow.
ok i checked out the cowl, it's clean. i went ahead and checked the connections under the steering wheel for the obd port and it's fine.. don't know what else to do at this point..
i dont think they are really related to the obd2 scanner not working, but my power lock is not working correctly...i hear the air pump, and what sounds like the trunk locking/unlocking but in fact, it does not.
my keyless entry doesn't work after changing the batteries (need to reprogram somehow, i have tried various methods i searched, none of which worked).
radio stopped working.. i was tryin to get it out without the proper tools and somehow the power got d/c i suppose...awaiting the arrival for my removal tools
a regular scan tool will not fix this
Find a person with a vag-com scanner if they have one they most likely will know the codes to get you’re window/key situation fixed
You probably yanked something and that’s not good, does it not work as in doesent power on or does it say SAFTEY on the lcd screen?
