obd 2 not connecting
My check engine light is on. i tried to get the code with an obd2 scanner but it wasnt able to connect with the car. i have no idea where to go from here. Any help would be appreciated.
What scanner do you have?
Sounds like a K-line issue. If there's an aftermarket or broken radio in the car, usually you start there.
Check all the fuses. I believe there is a K-line fuse. Then, pull the radio and be sure te connectors are not cut up or corroded. Use some stabilant or contact cleaner on them and plug the radio back in.
