o2 sensor question
Old 04-10-2008, 08:49 PM
johnnythefox's Avatar
Default o2 sensor question
i feel kinda dumb asking this but, i searched for which oxygen sensor to get for a replacement that wouldn't cost alot, and found this result https://www.audiforums.com/m_350772/tm.htm, which helped, but i need a little clarification before spending money. Would any bosch universal 4-wire o2 sensor work? Or would it have to be the bosch universal 4-wire o2 sensor from ecs tuning? The one from ecs is roughly $100, but i found them on ebay for roughly $30. Would the ebay sensors work or not? Thanks for the help
Old 04-10-2008, 09:25 PM
ImTheDevil's Avatar
Default RE: o2 sensor question
The ones from eBay should work, as long as it's the same style as the OEM (ie, heated four-wire, etc).
Old 04-10-2008, 11:51 PM
jsgrabo's Avatar
are you looking for pre or post cat o2 sensor?
also, probably the cheapest way would be to head over to the junk yard and pick one up. $30 on ebay seems a bit cheap for me.
Old 04-11-2008, 09:48 AM
hartsoe1's Avatar
oxygensensor.com
$50 I believe. Bosch universal. Works fine for me.
Old 04-11-2008, 03:23 PM
wow, that web page didn't work for me at all. bummer.
Old 04-11-2008, 03:33 PM
feerocknok's Avatar
The Bosch part number is 15738. If you get a 15738, you'll be fine, no matter where it's from.
The OE part number is 13550, but that'll be the spendy one.
Old 04-11-2008, 03:35 PM
ah-ha! part numbers! now we're cookin with ole! those are the pre-cat sensor numbers right??
Old 04-11-2008, 03:41 PM
feerocknok's Avatar
Yup , for a '96 12-valve.
Old 04-11-2008, 03:50 PM
much appreciated, that rocks
Old 04-11-2008, 05:16 PM
hartsoe1's Avatar
oxygensensors.com
sorry I left the last "s" off the first reply. http://www.oxygensensors.com
Quick Reply: o2 sensor question
