O2 Sensor 4 or 5 wire?
I bought an O2 sensor from Autozone, it has 4 - wires (white, white, black, gray), the one I took out of mine has 5 - wire (white, black, gray, yellow, red). I checked twice and this appears to be the right sensor.
Not so sure what to do about the wire issue. Do I leave one off or take the sensor back?
Ideas?
Thanks,
Ideas?
Thanks,
your front 02 is 5 wires your rear is 4 wires... which one are you replacing?
they are color coded(plugs) so if you have a red end on the one your have it is the rear, also the rear "harness" is shorter than the front
i have an awm motor as well
