no spark in cylinders 1 and 4
Old 05-17-2010 | 04:27 PM
sean mc 69's Avatar
Default no spark in cylinders 1 and 4
for wat reason would their be no spark on cylinders 1 and 4..its a audi a4 1997 adr engine code.ive tryed changing coil pack and problem still excist
Old 05-17-2010 | 07:31 PM
bkraska's Avatar
Do a search on this forum for Ignition control module or ICM and you will see that it is most likely the cause of your problem.
Old 05-17-2010 | 08:52 PM
auditech79's Avatar
Agreed, the ICM (ignition control module) also known as the power output stage controls voltage to the coils, if that doesn't work, you won't have spark.
Old 05-18-2010 | 12:21 PM
sean mc 69's Avatar
sounds good to me but were is the icm ignition control module located on the car.its a adr engine code and uses a bosch coil pack
Old 05-18-2010 | 02:40 PM
rcheing's Avatar
a little more info please, what year/ size of the engine....I would start on checking spark plugs, coilpacks. You can swap coil packs and see if the problem follows the cylinder...
Old 05-18-2010 | 05:46 PM
auditech79's Avatar
Thats true, if this is a 2.8L then your problem isn't the ICM. On the 2.8L you have one coil pack fire two cylinders. If the coil pack is firing 1 and 4 then swap the coil set and see if the misfires move.
Old 05-18-2010 | 08:16 PM
bkraska's Avatar
ADR is a 1.8 I believe. He already tried to change coil packs so that is why I pointed him towards the ICM. You should find the ICM on top of the air box (where your air filter is)
iponnet
06-08-2010 03:08 PM
MoD3lag
05-22-2010 01:50 AM
brimhall99
10-15-2008 09:24 PM
goldenchild
07-27-2005 07:53 PM
apg96
06-09-2005 01:47 AM
Quick Reply: no spark in cylinders 1 and 4
