No fuel at the rail???
3,000 miles since a full engine rebuild on my 2001 A4 Avant 2.8
new oil level sensor
new fuel filter
just changed oil
cranks well
sorry in advance i an 16 and its my first car, and my first engine that i rebuilt, when it ran there where no problems with idle or anything like that
new fuel filter
just changed oil
cranks well
Check your engine coolant temperature sender. If you have to pump the gas or hold it open to get the car started that's a CTS failure. ECM thinks the engine is hot and holds the injectors open longer while cranking, basically resulting in a flooded engine.
