NO CEL, But Misfires! =( help anyone?
Go to my last post please...
Ok, heres the list of the 9 codes I got...howeverNO check engine light on!
the guy at autozone said this codes were stored...
P0134 - O2 Bank1
P1128 - Fuel air
P1582 - Idle speed control
P0171 - System Lean
P0139 - O2 Sensor Slow Bank1
P0304 - Cyl 4 misfire
P0506 - Idle Control RPM Low
P0303 - Cyl3 misfire
P1256 - Fuel Air
can someone help me? just tel me if im right or help me out?
the misfire just change the coil packs...
change the O2 sensor...
how do I fix the rest? =/
thanks 4 the help guys...
P0134 - O2 Bank1
P1128 - Fuel air
P0171 - System Lean
P1256 - Fuel Air
RE: Misfire! O2! Lean! Fault codes =( help anyone?
theres only the boost problem...
im suppost to be boosting around 16-17 with the chip and im only at 12psi max
when i run hard the car tries to boost higher but looks like something is wrong.
yea im gonna clear the codes and then see if they come back.
yeah def. clear the codes and see which come back, cause with those codes a CEL should have definitely been triggered. with the syptoms you were describing in the second post you most likely have a boost leak
to find the leak
http://audizine.com/forum/showthread.php?t=64411
http://audizine.com/forum/showthread.php?t=104080
or just have a shop smoke test it
and then post the codes that come back
to find the leak
Sorry been away from theforumsfor a little while....
I wanted to trade my car for an B6 but I dont think Im going to have the $ to pay.
so im just going to Fix the Little probems Im having with this car....
The "boost leak" was the DV that had a rubber twisted and i fixed that.
but I think i have some misfires, sometimes it makes a weird noise while driving...
Still with no CEL...
I was wondering if the ECS Tuning coil pack is the best deal around.
the Coil pack'sPart# 058 905 105 "S4"
i appreciate the help guys.
