nitrogen
Old 11-20-2008, 05:55 PM
flynnr's Avatar
Default nitrogen
ok so i went in and applied at granite city tire and auto today, and i saw an advertisement...
ive never heard of this.....
true?
Old 11-20-2008, 08:47 PM
airguard350's Avatar
Tech Guru
^ Entirely
Old 11-20-2008, 09:59 PM
huffer81's Avatar
I fill my tires with nitrogen from te dealership I work at. I just checked them yesterday for the first time in 5 months and they only dropped 6psi. They don't seem to change pressure with the air temp like regular air does.
Old 11-20-2008, 10:57 PM
FASTER's Avatar
Tech Slut
if the valve stem has a green plastic cap it means it was filled with nitrogen... I think costco uses it.
Old 11-20-2008, 11:53 PM
SAudi's Avatar
of course, because regular air is just too unstable. but seriously, its exaclty as it advertises, its usually used on high performance cars like the nissan gt-r, i think its to help the tires run cooler at higher speeds.
Old 11-21-2008, 12:27 AM
kraylon's Avatar
i have heard that Nitogen doesn't expand as much as air does, but with that my question is tire companies know that air expands under heat, i am sure they figure this in when they are designing a tire, so does having your tires inflated with nitrogen hurt or help the performance of a tire???
Old 11-21-2008, 02:46 AM
kendalll's Avatar
I prefer to use a special high performance blend of 78% nitrogen, 21% oxygen, and 1% 'other'.
Old 11-21-2008, 06:08 AM
roll4ever's Avatar
ive read about it and heard it doesnt really do much
Old 11-21-2008, 10:29 AM
CRAZYHAWK's Avatar
I'm with Kendell, normal atmosphere.
Nitrogen doesn't hold moisture.
Old 11-21-2008, 04:14 PM
flynnr's Avatar
cool. thanks, how much does it cost to get filled?
Quick Reply: nitrogen
