New rims!
New rims!
Birthday weekend last weekend and picked up some rims. VMR V715 powder coated gold with chrome lips. 19"
The bad. (Need Advice)
Im pretty sure when i turn it rubs against the control arm when i turn, i have nauspeed lowering springs in the mail right now (1.25") and i was wondering if this would case a problem when i install them. do i need spacers?
also *****y gas milage right now.
what do you think, gold n silver
if you're rubbing at 4x4 hieght, then you'll rub worse when lowered.
What size tire are running? Whats the wheel offset? Whats the wheel width? This info will help people offer the correct advice as to what will help your rubbing issues.
Diggin the wheels tho.
I'm on 19x8 wheels with 235s and I had to run 5mm spacers to keep the tires from rubbing the uprights. My offset is 42, so the spacers give an effective offset of 37. Like the others said, what tire size and offset do you have?
i just went out and did the offset calculation for my rims
i came up with
19x8.5
38mm offset
5x112
running kumho wheels 225/35-19 (i think thats size) info below
i got my springs in the mail but am kinda of sketch to put them on.
tires
http://www.tirerack.com/tires/tires....num=235YR9KU31
rims
http://www.velocitymotoring.com/wheels_v715.html
springs
http://www.mjmautohaus.com/catalog/p...products_id=69
i came up with
19x8.5
38mm offset
5x112
tires
rims
springs
mnesvade
05-25-2012 06:13 AM
santon
03-03-2008 02:14 PM
