New Owner Needs Help
Hey yall, just traded for an 01 a4 avant and have a few questions. First what is the box bolted to the top of the rack that holds the 6 disk changer? 2nd what is the vaccum hose pictured below? and third what do these wires go to in the second and third pic they are a white and a yellow. thanks for the help im gonna go try to find my coolant leak.
The vacuum hose goes to the accumulator in the left front fender. It's a blue plastic bottle that is shaped a bit like 3 *****. With that vacuum hose going nowhere, you have a big vacuum leak.
Not sure on the wires down front, but given that location I would guess they go to the ambient air temperature sensor. It's supposed to sit down low at the bottom of the AC condenser on a plastic bracket. If your instrument cluster tells you the wrong temp, that's another reason to believe those wires go to that missing sensor.
agree
yeah I just got done pulling the front end apart and found where the vac line runs now just to get one....
I didnt find anything with wires ripped off and my out temp seems pretty close to right but who knows exactly.
I found a crack in my plastic thermostat housing, I think I can change it without pulling my t-belt, it was done not long before I got the car and they did the water pump with the t-belt. Do you know if it is feasible to yank that housing without pulling the t-belt( or acc pully on crank)
There are guys here who have done that. I tried it once and just ended up scarring the surface that presses against the gasket.
I believe the metal and plastic ones are interchangeable. My 99.5 has the metal one, don't know about the others.
thats good to know, I endued up using some epoxy repar putty on mine and it seems to be holding. Thanks for your help im sure I will be begging for more when I get my new exhaust leak taken care of, Im starting to not feel good about this trade
CasopoliS
05-22-2011 12:15 PM
cool_kyle_3000
10-04-2006 04:46 PM
