Need some help here....probably electrical.
Try unhooking your central locking pump in the trunk. Then see what happens. I saw a post not to long ago with someone who purchased a car with the CLP disconnected. When he reconnected it, the alarm would go off etc. You could give that a try to start. The person who posted the thread didn't have all the problems you are having, but its worth a shot.
As for the bump, it could be the rear diff bushings, engine mounts, snub mount or tranny mounts. Or a combination of those things.
it sounds like something to do with your alarm not turning off. when the alarm is (stuck) on, your window and lock buttons on your door will not work, and obviously your marker lights will flash when the alarm is going off.
Thats sucks. I believe it's going to be a dealer-only item. Give your local dealer a call with your VIN and see what they say. You can scan junk yards too, but it's not uncommon for the alarm unit to fail in an older A4.
And fix your water leak before you replace any expensive parts!.
ditobot
02-06-2012 10:51 PM
