Need some help
That fault code usually means your battery got drained at some point. DV should be fine. If it was leaking 14psi you'd most likely hear it. If you have a volt meter you can test power to the n75, and check it's resistance. Though, Idk what the resistance should be. Search on that.
Hey guys
Ok so its been a while but I finally performed the boost leak test and ended up finding a leak so I have fixed that but still im getting 3psi if im lucky. I am getting really frustrated now because I want my car to have its ***** back but is there any other ideas as to what my boost problem can be?
yea I re scanned it and no fault codes were found. I dont have a check engine light on or anything still. I just hooked up a pressure line to the waste gate and it blew off that pressure so I think that means its working. I am doing another boost leak test now but 90% I have found all the leaks
