need pics and advice on 19" hp designs on b5 a4
wut offset are they? You should go ask the S4 guys but I think you'll need spacers in the rear. The front might be fine with the size tire you put up. I'm running 235/40 on 18x8 all around with 35mm offset without spacers, lowered on HnR race springs and no rubbing at all. It barely clears everything though. You can take my size and compare it with what you want and see the difference in size. I wouldn't get bigger tires than what I have though.
i've been running staggered for over 4 years with no issues.
as for tire size, i'd run 235/35 in rear and 225/35 in front.
not sure if you'll need spacers or not. if you do, i can't imagine you'll need anything too aggressive.
There's no issues if you don't mind the extra understeer. I guess if he's going for 19"s, it's gonna be a show car anyway.
#18
With a Torsen-diff Quattro setup, the axle with the most resistance (grip) will get more torque and the only EDL is electronically activated, which will not be an issue front to back, but only side to side. With ESP, however, it does complicate the system with more electronics involved which may be negatively affected by staggered wheels or a difference in rolling diameter.
Either way, a staggered setup on a B5 will cause unwanted understeer. If this is a show car, you'll get used to it on the street or might not even feel the difference unless you're driving at the limit.
rocketruss
11-21-2012 02:04 PM
