Need to lower my 98 A4 quattro
I've heard mixed reviews that seem to be directly related to how low people set their ride height, which I think is to be expected. If you buy cheap coils and then dump your car on them, the ride is going to be bouncy. They seem to be fine at what I would call "reasonable" ride heights though. I'm planning to buy a set myself this coming spring.
the previous owner of the car put brand new shocks on it right before i bought it so they have under 5k miles on them. So shock wise i should be good and i have the ability to take the car into the base auto shop and swap the springs from the struts. so i'm only going to be needing springs, so with that in mind what options do i actually have with the 1.8t engine?
Rear suspension between Quattro and FWD cars is entirely different (but the front is exactly the same).
V6 engines are heavier and thus the front springs for a V6 car will be stiffer... and when put on a 1.8T car will cause that car to sit high in the front. If they're coilovers then you could adjust for this height discrepancy.
audia4012.8Q
09-08-2010 09:36 PM
