Need help asap plz.
RE: Need help asap plz.
Same exact thing happend to me (dead bat,jump, TB fault), and multiple TB alignment attempts is what eventually worked. But my car was driveable and rpm's were stable. I think I finally got it to work after several drive cycles.
I'm DBW and you are DBC, so I guess we arent comparing apples to apples, but same concept I suppose.
I have P1545 too...
I have the same problem here.
My 99 A4 V6 Quatto was sitting undriven for 3 months during summer.
Dead battery and then with code P1545. Now need to give gas to start, up/down rpm between 1200-to-1600 rpm while giving gas. Misfire, no power and not willing to rev above 3000 rpm.
vag-com code said P1545. Tried throttle adaption but it gives "adaption status: ERROR"
One of the TV angle is 25.6 degree (suppose 0-5 degree).
Reset the code, but it still have up/down rpm but not improving.
I have the same code again after car ran for a few minutes.
What is the cure ? What am I supposed to do from here ?
How can I adj the TV angle back to normal angle ?
Thanks in advance.
-Tat
Thanks in advance.
-Tat
