NEED HELP
Old 04-01-2008, 10:24 AM
NuYorka103185's Avatar
Default NEED HELP
So does anyone know about this little plug on the back of the ATW engines. Its like a big metal plug that fits into a hole for coolant. Anyway it keeps popping out and and leaking out all the coolant. I dont know why or how to get it to stay in. There is this stupid little metal clip that looks like its supposed to hold it in place but it does NOTHING. I just got it back after getting the new motor installed, it runs fine except for this one stupid part. Does anyone know what Im talking about? I can't drive it cuz of this one stupid part since it leaks out all the coolant. PLEASE SOMEONE HELP!!! What can I do or what do I need?
Old 04-01-2008, 11:40 AM
hiwords's Avatar
Default RE: NEED HELP
om cincytt or one of the techs
Old 04-01-2008, 01:16 PM
okay its the coolant temp sensor or sender, whichever is on the back of theblock up top. How do I get it tonot pop out?
Old 04-01-2008, 01:18 PM
sineo's Avatar
Get a new clip from Audi.
Old 04-01-2008, 01:26 PM
should it be popping out like that though?
Old 04-01-2008, 01:35 PM
chaos92287's Avatar
if your positive you have the little metal clip on right, then just get a new one at the stealership.
Old 04-01-2008, 01:56 PM
the metal clip doesnt seem to do anything plus I have no O ring. Okay someone tell me what they have on theirs ( as far as additional little partslike O rings and stuff)and how they clip it in
Old 04-01-2008, 02:14 PM
chaos92287's Avatar
they used different sensors throughout the years so yours is different than mine. but it should be apparent how it works by looking at it. the clip should go over the coolant flange and fit into a groove that holds it in place
Old 04-01-2008, 02:31 PM
the clip goes in the grooves but doesnt hold anything in place
Old 04-01-2008, 02:34 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: NuYorka103185
is there a grove in the hole of the block?
might be that that is how it is supposed to be, but there might not be a grove in the block for the clamp to fit into
if this is a plug that is not supposed to come out, you never want out....... jb weld the plug in there
