N75 delete
N75 delete
Hey all
so, i searched, and I know i have seen various threads before with the writeup...
I am running a mbc with the n75 right now, I would like to switch over to just an mbc...
I believe I have to run a vac line in a loop running from-to the n75...
a link or a pictorial would be greatly appreciated
AEB, KO4 PC16
thanx in advance!
AEB, KO4 PC16
thanx in advance!
I do not plan to unplug my n75...I plan on plumbing the vac lines to trick it into thinking it is still serving as a boost controller...
I have seen a handful of setups that have ran 100% with a "tricked" n75 and using a mbc for boost regulation...
I know I have seen a pic of the setup I want to run on here somewhere, but my searching is not coming up with what I am looking for...
you don't need to run any vac lines to the n75 if your going to use just a mbc.
just keep it electronicly connected. i have mine just electronicly connected and stuffed it near the fender.
my mbc is the only thing connected with vac lines.
https://www.audiforums.com/forum/diy-do-yourself-55/how-hook-up-mbc-68777/
found the thread that I was looking for, will update with results, I am going on a 500 mile road trip tomorrow and am going to up the boost...
