The Mysteries Of The O2 Sensors
I would just like to mention I have the 2.8, not the 1.8 so my 02 sensors are located right after the exhaust manifold and then another two between the flex pipes and the cats.
That's why I was asking. Apparently it is different in the turbo models.
Nope, pretty much the same setup. It's mostly universal on all cars since the early 80's. The only difference is there's a turbo after the manifold and before the first O2 sensor on the 1.8T. Oh, and there's only one exhaust manifold.
Closed case.
Kamil, you're both wrong and right. There are 2 styles of 2.8 downpipes, one with a precat and one without. If there's a precat the second O2 sensor goes after it but before the main cat, if there isn't one it goes after the only cat. Side effect of this is you can do whatever you want with the main cat without triggering a code if your car has precats since only the precats are monitored.
The ECM is back at the tuning shop to have the issue resolved, so the car's undriveable for the week anyways.
Technically you're wrong since the cats are go after the flex pipes on a 2.8, but that's just semantics and means nothing. The thing is, if done properly an O2 sensor delete doesn't need the sensor plugged in at all, the fact that you're getting a code means it was done wrong. What code do you get from unplugging it? My guess is it relates to the heater, so maybe try unplugging/snipping the wires that don't go to the heater just to prevent the open circuit code as a temporary measure until you get the software issue sorted.
