My update thread!
#24
I've been searching and cant find any where that has an adapter for 5x100 wheel to 5x112 hub so looks like i'm screwed... I'm going to try and see if the guy will give me $$$ back or re sell!
#25
http://adaptitusa.com/boltpatternguide.aspx
EDIT:
This looks like the one you're gonna want, but they aren't cheap. You can get them in different thicknesses too which is kinda cool
EDIT:
#27
Is it possible to do a TT swap?!
EDIT: These are the ones I need (i called) http://adaptitusa.com/5x112to5x100wheeladapter.aspx which I can get 20mm roughly 3/4inch said I could get all i need + shipping for $209 est. 10 days So then I'm down to space + is the $$$ worth it?
Thats the thing I watched hm pull them off the A6!!!
#28
18x8 ET33 shouldn't poke tooooooo bad, but you're right, 25mm is pretty friggin big. I think you should mock them up on the car with an inch of somethin between the hub and wheel and see what they look like before you go droppin $200 on adapters
#30
Edit: I'm going to go into the shop tonight and take a wheel off and try and lower the car on just the jack to about ride height to see rub/poke and then do a pick with a 20mm gap!
