my headgasket change.
#22
So ordered more things for this. (most vaccum lines looked good) but ordered the whole kit since i broke one line. got mud flaps for it for 50$ =-] front and rear. greenspeed snub kit, ordered both timing tools (picked up the ecs tool kit for 50 yea your heard right 50)
getting most things tomm (tools for sure) so tomm i will be back out to the car to wrap her up hopefully. =-]
#23
Do you have a link for the ecs tool kit you got for $50. If you don't need it anymore I'll buy it from you for $25, plus ship! Both of my sons' A4s need new TBs. One is a 1.8, and one is a 2.8, 12v sohc. Will those tools of yours work on my application?
#24
Ummmm i got it off ebay, and i am most likely keeping it. they sell on ebay for 70 new (not ecs some off brand) and that tool would only work for the 12v
#25
Well thank god i decided to double check i believe my timing may be off. it's all lined up and then i'll put the tensioner on and apply tension and the timing gears will move a little bit.
Here are pictures to show what i am talking about! I do have a buddy who works at lexus and has worked on audis come by tomm to check it out but i thought i'd ask you.
after when i tried redoing the timing to make sure everything was good.
Now after all these pictures i did rotate the motor clockwise and there were no sounds. just the compression building and letting off. From all the motors i have timed they would never be off like this (although someone could of made there own timing marks hence why i ask you guys
let me know what you think.
#28
http://db.tt/06dSOGI
http://db.tt/C6MxF9h
These might be able to help you some with some of the features of the vacuum system.
Good Luck.
-Cory
Good Luck.
-Cory
#29
OKay started her up and got codes p0301 p1206 and p0102 and it was making a awful racket.... **** me huh.
those codes are misfire cyl 1, maf low reading, and fuel injector malfunction cyl 6.
what the hell do i do now.
#30
