My A4 went pooof and died.....Help
HELP!!!
I was driving, going about 74mph or so and I heard a noise go pooof, not too loud. And then the car turned off. I pulled over and it didnt crank. Its a 99.5 Audi 1.8T Auto. What you guys think it is?
1st things first. Did you look under the hood? Is a spark plug missing (presuming you aren't diesel), which could cause the ECM to not allow engine start? Plugs can get blown out of blocks, I've seen it before in V10's.
Is there a hole in the block (throw a rod/piston)? Did the engine overheat? Did the gas line come loose? Do you have compression in each cylinder? Are all the belts in the right places?
You need 3 things to run your engine. Air, spark, and fuel. Are all 3 there? If not, why not? When you turn the crank, is the cam turning? How old is the timing belt?
What codes are showing if you have a VAG?
