My A4 has bit the bullet!!!!
Old 03-21-2010 | 09:09 AM
burtonboarder84's Avatar
Unhappy My A4 has bit the bullet!!!!
I was pulling into a parking lot with my 01 A4 1.8t and the motor started knocking. CEL was flashing indicating a misfire. CEL code was cylinder 3 misfire. I replaced coil pack and nothing. Pulled spark plug and the electrode was flattened!! Either by cylinder or foreign object I guess.
Car has 155K. I always change oil with synthetic every 5k miles. Timing belt is fine. Any ideas what could have happened??? I'm going to do cylinder compression test today.
Old 03-21-2010 | 12:09 PM
pyropenguin's Avatar
check the compression and pop off the timing belt cover and see how it looks. you should be on your third timing belt by now....
Old 03-21-2010 | 04:28 PM
Unhappy cylinder head
Yeah I just had the timing belt done a few months ago. I looked at it and it looks fine. Something internal is damaged. What the hell can cause that? Not a sludge problem either.
A864.2
07-31-2012 08:28 PM
jagtoes
B7 Models
05-22-2012 07:48 PM
mudduck
12-02-2008 07:42 AM
EvilA4
07-17-2008 01:55 PM
kolbs_91
11-05-2007 03:54 PM
Quick Reply: My A4 has bit the bullet!!!!
