My A4 1.8T smokes like crazy, help!
It smells like burning oil, the smoke is a blue color. I pressure tested the cylinders and they were 180 psi across every cylinder, which i thought was pretty good. Im not throwing any fault codes for the oil issue or anything like that it, I did take the cat off and replaced it with a test pipe. Thats the only code thrown is the O2 sensor is at threshold or something like that.
Can you let it run 'til it starts smoking and then try and look under the hood to find out what part of the engine bay it's smoking from? Also, obviously, check your oil often and make sure you're not running out.
