My '01 Quattro sounds like a WRX!?
Just found the thread you started about clearing the CEL codes Ben... Looks like you have the same codes I did. I think I'm gonna try the test where I run the codes again and verify it's 2 & 4 and then clear the codes. Swap 2 & 4's coils for 1 & 3 and see if the misfire follows the coils. *FINGERS CROSSED*
Yeah same exact codes, I thought about doing that test (swap the coil packs around) but I figured I'd go ahead and replace the coil packs. Very strange that two went out at the same time though... I was almost certain it was the ignition control module. Apparently the coil packs are notorious on these cars.
Did I have the same noise as a wrx? I wouldn't say so but I was running on two cylinders for sure. It was very sluggish acceleration and stuttering any time I was on the gas. Make sure you don't run the car for very long lest you damage your cat. Mine was glowing orange from just a short drive to autozone. Best of luck to you.
bettsjb36
10-22-2012 08:33 AM
strokera4
11-16-2010 09:46 PM
