Muffler Bearings!
Old 11-12-2008, 05:48 PM
FASTER's Avatar
Tech Slut
Originally Posted by onepoint8tee
Noticeably down on power huh? Maybe your wastegate flapper broke. But I'm sure you'd get a CEL if it did being a 00+. In my 97 when the wastegate arm was broken I didn't get a CEL, just no boost.
good thought, but he didnt say he was out of power, just "down a little"... I bet the turbo is soon to be shot
Old 11-12-2008, 09:16 PM
EpicWin's Avatar
Sounds like it's coming from the valve train! Like a lifter gave up or something.
That's a hell of a rattle... when was the last time you changed those muffler bearings???
Old 11-12-2008, 09:41 PM
Tweaked's Avatar
I just pulled the cat back from the turbo. No metal shavings or broken fins. No monolith floating around. No shaft play in the turbo. Not even oil around the shaft!
I guess I'll have to pull the opposite side of the cat to check for damage on the other side of the monolith.
Old 11-14-2008, 02:05 PM
EpicWin's Avatar
Did you put the stethoscope on top of the valve cover? Give that a go and see if the cam chain is noisy... the guides, as you well know, are a wear item and might be starting to give the chain a little slack.
Old 11-29-2008, 12:54 PM
Tweaked's Avatar
It's definitely the cat rattling. It's getting worse and the car is a slug. I'm probably ordering up a Labree HFC next week. I can't go with a test-pipe because I'll fail visual inspection in CT. I give an update when I get a chance to order and install it.
Old 12-11-2008, 06:45 PM
Tweaked's Avatar
Just an update, Labree sent me a very nice high-flow cat. Great people, great service. I'll post again when I finally install it. Cold. Rain. Boo.
Old 12-11-2008, 09:05 PM
hiwords's Avatar
take a broom and clear it out for now
  #18
Old 12-11-2008, 10:15 PM
Tweaked's Avatar
Nah, MIL is off (knock on wood) for now. New cat is sitting in the box.
  #19
Old 12-19-2008, 12:38 AM
Tweaked's Avatar
New cat installed today. I'll post a little write up with some pics. Car feels like a rocket compared to the noisy, clogged OE cat.
  #20
Old 12-19-2008, 08:49 AM
CCA4's Avatar
You should cut open the old cat and see how bad the inside looks, i always got a kick out of takin stuff like that apart lol.
Quick Reply: Muffler Bearings!
