Motor removal/Front clip removal
#22
Disconnect your negative battery terminal and move it aside. Pop off lower grills, theres an allen headed bolt on the top of the recess. Its a long one, you'll hate it. Then you take off the bumper by pushing in and down. There are three hooks/claws holding it on, two up top one on the bottom. Its a pain in the ***, just gotta fiddle with it. Then pull the bumper out a bit, and disconnect the headlight washer line, (drivers side) and have a bucket ready. Now you're ready for the bumper shocks. Make sure that battery cable is off, then use your Torx head to undo the 7 or 8 bolts holding the two large black forks sticking out. You'll also need a 10mm socket to get the retaining nut. Move these aside, not which is which side. Next its time to drain the coolant, which can be found at the bottom drivers side of the radiator. Remove the expansion tank cap first. Undo the screw out plug, catch the coolant and prepare it for proper disposal. Protect the environment my friend. Then you can begin to disconnect the upper and lower radiator hoses. There's a screw clamp and two metal clips that just need to have the metal wire pulled out to release it. At this point you're ready to remove or at least disconnect the headlights, which are wire spring connections again. Now you should be ready to take off the core support. Its four bolts up top, right next to the fender and on on each side, holding the black core support to the metal fender support. Those last six bolts are all thats left. The only thing holding you back now is the A/C condenser, which is the black bar and fin panel in front of the radiator. No need to remove or disconnect this, as you can swing the entire core support to the passneger side thanks to flexible refrigerant hoses. Viola! There's your engine bay in all it's splendor and you are now in service position. I've got my time down to an hour! You may want to remove the lower intercooler pipe, the metal pipe that runs under the motor to... the intercooler! Again, two screw clamps, then you can check this pipe for excessive oil and or metal shards, which hopefully you dont have. All this information, and much much more is included in a Blauparts timing belt kit instructions. Good luck!
#27
Are you pulling the trans too? Because none of that needs to come out for just the motor. But the halfshafts bolt in if you are taking them out. There are 6 or 8 bolts with poly, allen, or torx heads on them depending on what audi decided to put in yours lol.
#30
Do I have to take off the rotors and brakes and remove that center nut to pull the axles?
