Motor Pull
Motor Pull
So Ive been at it for about a day and all necessary connectors and vacuum lines are disconnected and it looks like its ready for the motor to be pulled but i cant get to some of the tranny bolts where it connects to the block. I was wondering if anyone could give me some tips on this. And i was also wondering if its necessary to pull the sub frame to get the job done? I need to pull the tranny also and was just wondering what the best way to go about all of this would be?? Any helps appreciated!
Thanks
Zach
Thanks
Zach
Which bolts are giving you trouble? If it's the bottom ones that are blocked by the subframe, you can jack the motor up (loosen motor mounts), then you can get them from the front with a long extension or two.
I'm just paranoid, but make sure you don't get yourself under the motor where it could hurt you. I always assume the chain/jack/whatever could let go at any moment.
lol ghost, i bet 50% of your posts are asking that question you asked, or telling people they need to give more information about their question, and then you never end up helping them
no hard feelings ive just noticed that over the past few months on this forum
anyways, i cant help with this question either sorry for the temporary thread jacking, go on
Ya i got that part but if you are facing the car on the bottom right of the tranny there is a bolt with a nut and you cant get at either end with a socket or a wrench.. the bell housing is to close to the head and nut.
