Misfiring Problem (2001 1.8T) Not plugs or Coil Packs HELP!!!
+1 A bad coolant temperature sensor can really throw you off. I had a similar issue and thought it was coil packs after i replaced my plugs, but ended up replacing the ects and it took care of it. For this reason every time I've bought a 1.8T its the first thing i replace, I've found them from $15-25, so its worth replacing.
I am having the same problem with my 99 audi a4. checked everything, switched coil packs, spark plugs MAF power control module, fuel filter air filter everything, still stuttering, comperession tests were fine, only stuttering in cylinder 1 and 3. don't know what it could be, paid someone to look at it and even they said they have no idea, they tested everything all wires to coil packs, cat is fine, o2 sensors are fine, everything.
#20
Also, even though you replaced the coilpacks doesn't mean that you got swapped a good coilpack. I was in the exact same boat and couldn't figure out what the hell was going on. I ended up going to my dealership and they told me my coilpacks were bad, and they only had less than 100 miles on them. Changed out the packs and BAM, no more problems...Especially with our 2001 model, go to Audi and get the right coilpacks cause the ones you can get at local parts stores are garbage.
