misfire problem
misfire problem
So the other day, I turned my car on five minutes after turning it off and the car started shaking violently. I took it to get scanned and the code said cylinder 2 misfire. I changed the spark plugs and that did not help. I moved the coil pack from cylinder 2 to cylinder one. It is still misfiring so I will take it tomorrow to get scanned again and see if the misfire followed the coil pack. the people at autozone said that the car was rumbling way to much for it to be just a misfire. Should the misfire not follow the cp, what else could it be?
thats the bosch sensor on the top held down by two screws correct?
I am looking on ecs, and they have multiple ones, will the cheaper Huco brand one fit my car? All I need is for it to run smoothly before I take it to trade in
Thanks for the quick replies
Edit:
Oh and is there a way to test wether or not the ICM is fully functional?
Edit:
if ecs' site says Huco will fit your car, then it probably will. you can also look around in the classified section for people parting out their car.
i have the same problem, got the ecu back to the house scanned it it said cylinder 3 is misfiring swapped the coil packs and retested it still says its coil 3 misfire.... gonna go buy a new icm...... if its not the icm what else should i look for before i really have to bring it to the shop??????
99% of the time, it will be because of either: a bad spark plug, a bad coil pack, or a bad ICM. the other 1% of the time it could be a stuck fuel injector (very rare) or a bad valve seal/guide (also rare unless you had a foreign object get sucked in or a timing belt issue), or bad head gasket or low compression.
