Memoscan Problem
I couldn't get a cheap ebay cable to work no matter what, I messed with port settings, drivers and I even installed XP to see if it would work on that. Nothing worked, I even tried another cable and same results. I returned it and bought a VAG908 replica and got everything running within minutes because the drivers are just modified legit vagcom drivers.
you wouldn't happen to have the exact reseller name from whom you got the Vag-Com cables on ebay? I have found that ebay can be a hit/miss sort of experience and unless you get the right seller your results can vary drastically.
all 3 worked with this one version of vag-com software but did'nt work with a different version software,that is how i know for a fact,that hardware isn't the issue,its the software.
pm me to let me know if you are having issues and i'll help you configure the windows and vag-com software settings.
