MBC Install
ok so i bypassed my n75, something i didnt see anywhere is, should i leave the n75 connected by the 2 prong connector, and should i connect the 2 nipples on the n75 together with a short piece of vacuum hose?
https://www.audiforums.com/forum/sho...d.php?t=111404
You don't need to loop the nipples on the n75, but you could if you really wanted. I've tried both ways before and didn't notice a difference if there was one to be made.
You only need to loop the 2 nipples on the N75 if you are leaving the 3rd nipple plugged into the turbo inlet hose. The reason for this is because if you dont you end up allowing unmetered air into the intake system.
ok thanks, its dark out now so ill loop it tomorrow morning, i have off work so its a perfect opportunity :P
