MBC inplace of N75??
I recently got my 99.5 1.8t FWD chipped and am only boosting at 11psi. i fixed all of the vac leeks and such. Still only 11psi. I took the hose from the N75 off the wastegate... okay so now it boosts at 18psi and probably higher. what i want to know is does the wastegate need to be replaced or is it the N75 that needs to be replaced?!?! (wastegate does rattle a little when i let off the gas... or atleast i think its the wastegate) Other questions is can i put an MBC inplace of the N75... if No then why not? just wondering because i dont really understand what the N75 does. What is the problem.
RE: MBC inplace of N75??
its the n75, never the wastegate. Yes you can change the n75 for a mbc np. But you need to make sure your wastegate is tight and doesnt rattle otherwise your losing flow to create boost
cincytt how is it that i can tighten the wastegate? are there any writeup or ...? other question is which MBC should i purchase? would i be better off with MBC or a new N75?
thats not the valve, that the regulator for it. It controls the amount of flow back into the intake. It really should be tossed and a catch can installed the moment you buy the car imo
