Max Boost = 4psi . p1338 code have anything to do with it?
Old 03-23-2008, 01:23 PM
zat0rsk1's Avatar
Default RE: Max Boost = 4psi . p1338 code have anything to do with it?
thank you gio. ill get my mechanic to look at this post cause i have no idea wut most of that means. thanx man =)
Old 10-11-2010, 09:51 AM
kepo's Avatar
Bump!!!
I know this is an old thread but I am having the same problem. Have anyone else had this problem? My car (99.5 A4 1.8T) seems to be in limp mode as well and is showing the P1338 code. I have since replaced the cam position sensor and the code came back. It can’t be boosting more than 4psi cuz like the OP said buses and work vans beet me off the line. A friend of mine was thinking that the cam chain was off a tooth but on another thread it was stated that if that was the case then it would be obvious as the engine would be damaged. Please Please help!!!
Can anyone direct me to the ECU fuse? This Thread is from back in 08 so I am sure that someone out there has overcome this problem.
Jeremy Decker
06-18-2013 10:52 PM
89MustangGX
01-04-2011 12:29 AM
BoostLover97
11-25-2010 09:10 AM
skoehle1
01-29-2009 10:02 PM
zat0rsk1
08-29-2006 02:50 AM
Quick Reply: Max Boost = 4psi . p1338 code have anything to do with it?
