Manual transmission difference
Ok so just had my 96 a4 2.8l 12v 5 speed Quattro towed into the shop. Throw out bearing is shot. My question is my bad trans is transmission code CXW I have a spare transmission from my 97 Audi a4 2.8l 12v 5 speed manual with 100k less miles on it but the code is DJP can I swap a DJP into my 96 that had a CXW. If so what else do I need just the trans or do I need the Ecu or anything
the 6 speed isnt much better for our engines from the reasearch i've done. and i know what your talking about. i'd love to get more out of 1st especially, but the rest of the gears arent much better. from what i've gathered, i would say running a 5speed from an older 5 cyl may be your best bet. another option is the new 01a 6 speed, which is a direct bolt on minus the shift linkage, but since they are out of the newer cars they cost a lot more. you can run any 01a as a bolt up, which includes all 5speed non-01e's from previous years plus b6 1.8t's 5 and 6 speeds. the b6 3.0 6 speed is an 01e tranny which is not bolt up
Boostfreak94
05-27-2012 12:22 AM
MULEPERFORMANCE
01-12-2012 09:35 PM
parkertseng
01-21-2006 01:58 AM
