Maf
If you unplug the maf the ecu will just end up using the 02 sensor readings at idle/part throttle to adjust fueling. Just try to stay out of boost if possible.
Better to drive it with the maf unplugged then to run a car on a bad maf.
thanks yall but whats funny is that my car wouldnt run with the MAF plugged in and i think it was the wrong MAF b/c after i had that one installed i had a really bad miss at 5k rpm and now that it is unplugged i dont have a miss i think it was the wrong MAF
